Number from Dominican republic not working
We call number call drop right away. Calls don’t show on history or anything
Sorry to hear, and please PM the FlyNumber or your username so we can investigate.
Edit: I think we found it - looks like your number ends in 1483, correct?
We see this should be OK now, please retest.
Yes, it is the number ending in 1483. Same issue call drop right after calling. do not register on history. tested on multiple carriers
Sorry to hear about this, we’re on top of it via our local partners and will update ASAP.
Any updates on this issue?
Very sorry for the delayed update, and you were updated directly.
The number is working and should be tested from the Dominican Republic—this is the case with most toll-free numbers.
We placed a local call from DR number ending in 4321
DO toll-free numbers should look like this when dialed:
809xxxxxxx / 1809xxxxxxx / 849xxxxxxx / 1849xxxxxxx
Is there any way to allow international call on that number? Also is this number portable ?
Generally speaking, toll-free numbers are not reachable outside their native country, not specific to Flynumber - it’s just how toll-free numbers work in general (across the world.)
You would need to contact the new carrier/provider - we would not block any legitimate port outs.
More info here
https://www.flynumber.com/docs/additional-resources/porting#porting-out-numbers
Local call are are not working getting a busy error on history.
This looks to be a different issue now - we see the calls in the logs, so they are coming in, but it looks like the forwarding number (the 1347 number) is busy or not in service. Double-check the number and make sure there are no conflicts as far as you dialing the FlyNumber from that same device the 1347 lives on.
You might want to try VoIP just to test.
Set “host” to iptel.org and “user/extension” to music to quickly test your FlyNumber. You’ll hear music when you call the number.
as per https://www.flynumber.com/docs/basic-settings/set-voip
