When I go to my PBX panel, and setup a voicemail, I opload a sound file. But when i call my phone to hear/test the voicemail message, the sound quality is very bad. The original recording (done with a pro mic) is good, but something happens to the quality when I opload it to the system.
Is there a way to get a better sound quality to the voicemail?
I have tried to remove the existing voicemail and reopload the sound file again.
In the panel, it sound ok (not as good as when I listen to the sound file via windows media player, but still ok). But when I call my number to test the voicemail, it sounds bad. I can hear the voicemail, but the sound quality reminds me of an old answer machine from the 80s.
We tested this and the audio played well for us ( we called the FlyNumber directly), although the audio after the person module was slightly louder than the audio right after the time module( with the no cable)
Was the issue happening when you reach either voicemail module? ( as you have 2 )
I would also try calling the FlyNumber from a different operator/phone just in case thats the issue
Finally, we also uploaded a sample voicemail audio on your Phone system, its not attached to anything but if you can attach it and retest that can perhaps help us diagnose this
