How to turn off voicemail for incoming calls
Hi, is there an option to turn off voicemail for incoming calls? So when someone calls my FlyNumber and I’m not able to answer, they can’t leave a voicemail but instead just hears the automated message for being currently unavailable and to try and call later. Thank you for your help.
Yes, of course. We had set up the VM in your panel at signup as an example, as you see in the below screenshot.
We disconnected it for you. You can instead add an “Audio Playback” module (first record/upload an audio file in the “Audio files” menu).
