I have wasted far too much time dealing with this product. I never got the service running in a way I could rely upon. Always problems and sudden blocks with more payments. The android app rabbit hole was 2 months of nonsense that I should never have put with.
now you unsubscribe page is not working.
ANNOYED
Hi @Linguini,
Apologies on this; it was due to the new site panel update. You were on the legacy system, which caused a small issue.
We took care of it, and you can unsubscribe if you wish to.
The last couple of payments were declined on your side, unfortunately.
Either way, the new system is much better and more efficient. You have an internal SIP where you can use our SIP credentials to make and receive calls if that works. You would need to edit the email on the legacy account if you want to create an account there.
https://panel.flynumber.com/login
Thanks, and here if you need anything.
