Number displayed as active is not active
I bought a number a few days ago but parked it, today when I finally tried to use it I realize even if it says active, it is not.
I tried to forward to a number (without credit, just to hear it ring), and try to call it from yolla a few times.
I configured it with SIP address to forward to Twilio and also the [email protected] quick test suggested Legacy: Set to VoIP | The FlyNumber Docs
The problem seems to be the call is never reaching flynumber.
Hi @migsar,
We’ve checked this on our side: the number is active and routed, but none of the test calls reached it. The carrier that delivers calls to it has no record of any attempt today, which is why nothing shows in your call logs. The calls are being dropped before they leave the calling side, and with a new Mexican range that usually means the app or carrier you’re dialing from doesn’t route to it yet.
We’ve replied in your support conversation (it goes to your email too) with what to try next, so nothing more is needed here.
Hi @migsar,
Closing the loop here for anyone who finds this later: it wasn’t your setup. The carrier traced it to a routing fault upstream in the Mexican network for that number range and fixed it on 20 October. Calls are reaching the number now, and the second number you picked up worked from the start because it sits in a different range.
If a call from a particular network still fails, send us the time and the number you dialled from in your support conversation and we’ll take it straight back to the carrier.
