Can flynumber be forwarded to Magicjack? Magicjack says it is a VOIP service but you do not list it in your list of VOIP providers.
Yes, technically we can as you can just forward the flynumber to the USA magic jack number. It would be .01 per min to forward to a USA number
Unfortunately, there is no VOIP method of forwarding to them as they dont allow it. We can send calls to any SIP uri or plain old IP address if they can provide you one but doubt the would.
Thanks and here if you need anything
