Phone.systems app android setup
I cant get phone.systems app to work
I followed all the instructions in the welcome email
hit the activate link in the email and the app said setting up and activating but I cant make calls. All I see is a settings page. No dial pad or contactsd or anything like that.
Ive uninstalled and reinstalled same thing
Ive logged into the website, hit launch phone or whatever
crawled through endless settings
added more money
Can I use another app, perhaps Zoiper?
Could you take a screenshot and post it here, please?
Do you see a green indicator at the top of the app showing you’re online and logged in?
We just had the app resend you an invite (which you can do from the users menu).
You can use it, just set a SIP account as a contact method.
Then add it to the ring group in the panel (which you already have there).
Use the SIP account credentials from the “Contact Method” in Zoiper or any other SIP client.
Thanks and standing by.
This WAS the welcome screen (when installed)
Is this correct?
Where is the dialpad and contacts and so forth?
Now this is the welcome screen when launched.
Tapping on setting s just reveals this
no other options
yes I used the code to register the app after installing
:Do you see a green indicator at the top of the app showing you’re online and logged in?
NO!
Where do I find the SIP account?
Its been more than a year since I did any of this and I dont remember all these details
I cannot get into Zoiper on the android phone (its asking for login which I dont remeber) so I cant go to: “Contact Method” in Zoiper
Please let me know what hours you are vailable by phone. This is too painful too do one step at a time over weeks by emails :confused:
It seems it’s set up, but what happens when you go back to opening the app after the settings were opened?
Also, we can set up the SIP from here and send you the SIP credentials directly. Let me know, and I can send that via the account directly.
YES, Please get this running. I am very frustrated
When do you answer your support ph number?
Hi @Linguini,
Apologies on the delay with this.
This was updated via email in regards to the app screenshots.
Could you please check that out and provide feedback?
Sent you some screenshots.
How do I set up zoiper?
Where is my zoiper account login info
I tried the temp account you made (thank you) but it says no connectivity
If anyone comes across this thread, that info would be under Contact methods, SIP accounts.
