No incoming calls on my voip provider
I´ve just received my Flynumber but I can´t get it to work with my voip provider to receive calls on my Android phone. Here is what I´m using:
My voip is www.freevoipdeal.com and I´m using mobileVoip and/or Zoiper for client on my phone.
Works perfect to make calls.
I´ve set up freevoipdeal.com/mylogin on my flynumber setup page and it does not ring on the phone.
Any help for a newbie would be kind
Best regards
Rod
It could be the URI you entered is wrong…
The call history shows errors ( set TO: date to one day in the future)
Perhaps you should check with them to confirm your SIP uri
In FlyNumber forwarding page ( My account > MyFlyNumbers) choose VOIP
If the uri is rodfn@sip.freevoipdeal.com
“Host” is : sip.freevoipdeal.com
"Details" is : rodfn
