Hi, I bought my FlyNumber after reading here that it was possible to do Simultaneous Ring call forwarding.
But when I try to use the Queue module to set this up, I don’t see the “Simultaneous” Ring Strategy:
Is there something else I need to do to make this work? I’m trying to forward my flynumber to two mobile phones, all in the same city in Canada.
At the moment this feature was removed due to technical issues, you can still use the person module and have 3 forwarding destinations at the same time ( without the above module)
Let us know if you run into anything
Ah yes, I see. You just have to click the “+” button on the person module.
That works perfectly, thanks very much for your help.
You’re very welcome and here if you need anything at all
