Hi Team,
Thank you for the information provided so far.
We are currently exploring a telephony solution for a confidential whistleblowing hotline covering five countries: Indonesia, Malaysia, Thailand, Vietnam, and Singapore.
We already have experience using FlyNumber and would like to understand whether your services can support the following setup. As confidentiality and anonymity are particularly important for a whistleblowing service, we would appreciate your clarification on the questions below.
1. Local Virtual Numbers
For each country, could you please clarify:
What type of local number is available (geographic/landline, national, or mobile)?
Setup or activation cost
Fixed monthly cost
Included minutes, if any
Additional per-minute charges
Regulatory or KYC requirements to obtain the number
Estimated activation time
Any country-specific restrictions
We would also like to estimate the total cost based on approximately 120 minutes of incoming calls per country per month.
2. Local Toll-Free Numbers
Could you also confirm whether FlyNumber can provide conventional local toll-free numbers in each of the five countries listed above?
For each available toll-free number, please provide:
Fixed monthly cost
Estimated monthly cost based on approximately 120 minutes of calls per country
Activation time
3. One International Number with IVR Language Routing
We would also like to explore the possibility of using one single international virtual number for all five countries.
Could FlyNumber provide one number with an IVR menu, for example:
The calls would then automatically be routed to different WBS operators based on the language selected.
For this option, could you please confirm:
Whether this setup is possible
Available number types and the countries from which the number can be accessed
Setup and monthly costs
IVR/PBX costs
Included minutes and additional per-minute charges
Any activation or configuration fees
4. Call Routing and Centralised Management
Could all five local numbers be managed under one FlyNumber account and one cloud phone system?
More specifically, could each number automatically route calls to different WBS operators?
For example:
Indonesia number → Indonesian-speaking operator
Malaysia number → Malaysian/English-speaking operator
Thailand number → Thai-speaking operator
Vietnam number → Vietnamese-speaking operator
Singapore number → English-speaking operator
5. Mobile Forwarding vs Softphone/SIP
We would like to compare the following two setups:
Option A:
Local virtual number → forwarded to the operator’s mobile phone
Option B:
Local virtual number → operator answers through FlyNumber softphone/SIP
Could you please provide information on:
The cost of forwarding calls to mobile phones
Whether there are any additional per-minute forwarding charges
Whether FlyNumber provides a softphone application or SIP solution
The cost of using softphone/SIP
The number of required licences and the cost per licence
Whether multiple operators can answer calls through the same account
Whether calls can be routed to different operators automatically
6. Confidentiality and Caller Privacy
As this solution will be used for a whistleblowing hotline, confidentiality is extremely important.
Could you please clarify:
Can the operator see the caller’s telephone number?
Can Caller ID be masked or hidden from the operator?
What call metadata is retained by the system?
How long is call metadata retained?
Can we define or customize the retention period?
Can callers contact the hotline while hiding their Caller ID?
Is call recording enabled by default?
Can call recording be completely disabled?
If calls are recorded, where are the recordings stored and how long are they retained?
7. Recommended Configuration
Based on the above requirements, we would also appreciate FlyNumber’s recommendation for the most suitable and cost-effective configuration for a confidential whistleblowing hotline covering Indonesia, Malaysia, Thailand, Vietnam, and Singapore.
Our current options under consideration are:
Five local virtual numbers, with each number routed to the appropriate local-language WBS operator.
Five local toll-free numbers, where available, using the same routing arrangement.
One international virtual number with IVR/language routing to the appropriate WBS operators.
Thank you in advance for your assistance. We look forward to receiving your feedback and pricing information.
