Inquiry About Polish Virtual Phone Number Service
I am interested in obtaining a Polish virtual phone number through your service. Before proceeding, I would like to clarify a few points to ensure it fits my requirements:
  1. Will the number allow me to receive incoming calls from Poland while I am located abroad (specifically in Bangladesh)?
  2. Can calls be forwarded directly to my current mobile number in Bangladesh, or would I need to use a VoIP application/SIP client?
  3. Does the number support incoming SMS (e.g., for verification codes)?
  4. What are the monthly costs, setup fees, and call forwarding charges (if any)?
  5. Are there any minimum usage requirements or risks of the number being deactivated if not used regularly?
  6. What type of documentation or verification do you require to activate a Polish number for a non-resident?
I would appreciate your guidance on the best plan for my use case.
Hi @AzmaeenAshraf and thanks for posting.
Yes, you will be able to receive calls no matter where you are.
You can use either. When sending calls to a Bangladesh phone number, there would be an additional per minute rate, whereas if you send to VOIP, there is no per minute rate.
We do have Poland 48-73 mobile numbers that support SMS. We have seen some success with verification codes; however, we can NOT guarantee it. Regular SMS from Polish mobile phones should work fine, though.
The Poland mobile is 9.95 USD for the number, a per min rate if you forward to a regular phone number.
You would just need to pay the monthly for the number - Polish mobile numbers are 9.95 USD per month. You have about 2 weeks to restore a number when you miss a payment - you will end up paying for the lost time. More info on payments and billing here.
Either a photo ID (if going under personal) or a company certificate (if it’s for business) - you’ll need to provide an address for either, it could be any address in the world.
Let us know if you have any other questions or concerns.
