Hi, I’m about to purchase a FlyNumber but I need some step by step help in setting it up. Do I have to sign up a service somewhere else to receive the calls what you forward? if so, can you suggest which one to use?
From there, I see I can use Zoiper to receive calls. I’m not sure how to get this to work.
Thank you.
Please PM your username and will set it all up from here and send you details on what to do on your side
Click sign up while logged in and order the number please
Number is ordered and status shows pending.
Thanks and we appreciate your business
Check your email/FlyNumber tickets and you’ll see all the info there
If you need anything just let us know
