Hi, I would like to know some details about the services you provide. Interested in buying a UK number, any other details about this service except what is provided on your webpage? (Virtual phone numbers from the UK | FlyNumber).
Do you have guaranteed caller IDs for UK numbers?
What documents and information are required to buy a number?
Thanks for considering us and appreciate the post.
Perhaps you’ll want to check out our documentation.
How will you be answering the calls? If you forward the UK FlyNumber calls to a regular phone number - you will get the caller ID of the person calling the FlyNumber.
In general, we pass whatever caller ID we receive over to you. Should be pretty reliable for UK calls.
There are no special requirements for a UK number.
Thanks and let us know if you have any other questions or concerns.
That works, you can use a VoIP app on the desktop to answer calls. Something like this post.
My apologies but can you clarify what you mean by “guaranteed” , if the caller ID comes in blocked or private no we wouldn’t be able to show you their caller ID. Otherwise it should work fine.
A UK number is $2.95 USD and if you use the above method (set directly to VoIP), its just that - unlimited incoming.
If you wan to call out with the UK number you’ll want our phone system - which is an additional $14.95 a month and a per min rate to call out. Comes with a bunch of features, like an app for easy setup, voicemail, call recording, time-based routing and more.
I mean that, for example, if I buy a UK number from FlyNumber, will that be shown to the person I call on the other side of the line, and not a proxy or routing number from another country as it usually happens, for example, a number from Croatia. I want only the number I buy to show as the caller ID on the other side of the call.
Aha, thanks for that and yes, we’ll always show the FlyNumber/ UK phone number as the outgoing caller when calling out. The easiest way to do this is with the app.
