I have a FlyNumber SIP account for the number +421 2 330 708 13. Registration works from a mobile connection, but it fails from our office network (same credentials, UDP port 5060, TLS disabled).
Details:
- SIP server: sip.flynumber.com, port 5060, UDP
- SIP account username: [USERNAME]
- Office public IP: [PUBLIC IP]
- Allowed IPs on the account: not enabled
- Symptoms from the office: no response to REGISTER (Asterisk logs “No response received”), and the server does not answer OPTIONS either
- Mobile connection on a different IP: registration successful
Questions:
- Is the office IP [PUBLIC IP] currently blocked or rate-limited on your side, for example after failed authentication attempts?
- If it is blocked, when will the block expire, and can you remove it manually?
- Are there any other restrictions on this account (e.g., transport, port, or source IP rules) that could cause the server to silently ignore REGISTER requests from our network?
- Can you confirm that REGISTER requests from [PUBLIC IP] reach your SIP server and whether any responses are sent back?
Thank you for your help. I can provide a SIP trace from our Asterisk server if that helps.
Best regards,
Patrik
