I’m trying to access the PBX panel from different browsers, but I get same white page
Only shows the background, and loading any elements
Sorry to hear and have you tried firefox?
Chrome should also work but if youre on the latest version of chrome you’ll need to follow these instructions
Let us know if you run into any issues
Checking this now and will update you ASAP
Hi Again
Can you please try again , this should be OK now
Thanks and standing by
working now, but only in Edge
FF shows black screen
Thanks and we suspect its a setting on Firefox. We just opened Firefox on a mac, it asked us to run adobe flash, we said yes and it worked
Perhaps clear the cache in FF and try again
Chrome is OK as well
