Need a Skype virtual number ported
I have a virtual US number from Skype that I need to get ported. I want to be able to make/receive calls and receive sms via an app in android phone even when I travel internationally. Are there any countries where I wouldn’t get calls/sms when traveling?
What app works with Flynumber?
Also what would be the charges for the phone number and porting, receiving call and sms?
Thanks.
Thanks for considering us and the easy method of using our cloud phone system to make and receive calls (comes with an app).
Normally $14.95 a month for the phone system; however, we are offering it for $9.95 for newly ported-in Skype numbers at the moment. There is a low per minute rate to call out.
SMS is sent to the email on file. You don’t need the phone system for this.
Not that we are aware of, and not by default.
Note: We have some new features in the works where you’ll be able to make and receive calls (as well as outgoing SMS) without the phone system coming soon.
You can create a ticket in your FlyNumber account (create an account here) with your Skype number and we’ll guide you through the simple process.
On your website the price for a US phone number is $2.95 per month. You mentioned that for phone system the offered price is $9.95 per month (discounted for skype porters). Why the difference in price? What is the difference in features?
If I just get the phone number (without a phone system), can i still receive calls and sms?
Thanks.
The phone system is an optional feature. It allows for more routing options, voice menus, call recording, etc.
Yes, you can. You can send the calls directly to a VoIP solution like this blog post talks about.
Or just forward the calls to a regular phone number for an additional per-minute rate (in addition to the $2.95 USD).
I set up an account and started the process to get a US number for a month. In the set up I asked for an area code 980 number.
I made a payment of 2.95$ from PayPal but the status is showing as pending (and my prepaid balance is showing zero).
My account is also showing an invoice in the amount of 2.95$. When will I be able to use the pre paid balance to get the number? And do I get to select my number from some available options within that area code?
Since I’m currently traveling I want to make sure that I’m able to get the flynumber set up working.
Thanks.
Hi there,
We do see the payment/order, and the number was sent. We have an updated panel in the world where you can choose a number. If the number you were assigned is not to your liking, please let us know, and we’ll send you some other options.
Then and here if you need anything.
