Hey,
Can you recommend a free SIP Client for Android which works well with Android? Tried the standard anroid sip client but got the message unauthorized. user/pass server and port are correct.
Hey,
Any SIP client should work fine, Zoiper on Android is free and should work OK as well
Hello i installed zoiper and created the SIP under pbxww( phone.systems) under flynumber but everytime error 408 . And the pbxww said everytime unreachable. any tip?
I tried use the official phone.systems android app but the problem is the same .
Can you try to ping the SIP server address/domain ( the one give to you in the phone.systems)
If its unreachable please PM or email your IP address , perhaps your IP was banned for too many failed attempts
https://www.zoiper.com/en/support/home/article/19/Error%20408%20Request%20Timeout
to me, just turning off rport did the trick!
