I’m looking to block some persistent incoming spam calls. How in the phone.systems cloud interface can I configure an area-code wide block? The blocklist object does not support wildcards when defining a blocked number.
Hi @Rolan
Correct but you can use the “Caller Router” object/module as a work around (for now).
Route calls with the area code you want to “block” to a “Playback” module for example stating their call will not be connected.
Let us know how this works out for you.
It works. Does the job.
Thanks.
Super and thanks for the feedback.
Standing by if you need anything.
