Australian mobile number
Hi team,
I’d like to ask if you currently have any Australian mobile numbers in stock. Also, how long after placing an order will the number be active and ready for use?
Hi @Odyssey and thanks for posting
Yes we do.
These numbers need to be “registered” (you can any address in the world) - usually a couple hours, 24-48 hours max.
I’d like to order a mobile number along with your phone system. However, I also have an existing SIP trunk from another provider. Should I place the order first, or would it be better to submit a support ticket to discuss integrating the third-party SIP trunk?
Hi team,
I’m still waiting for your response relating to integration with 3rd party SIP Trunk.
Hi @Odyssey,
Your tickets were replied to earlier. You can click sign up and choose the phone system (as you’ll need the phone system to enable the custom 3rd party trunks feature).
Thanks and standing by.
Thank you for your reply. I’d like to ask—if I register a mobile number under a personal identity, is it possible to later change it to a company identity, and vice versa?
Yes you can switch the registration from personal to business or vice versa.
