Yealink SIP phone
Hello
So i have a yealink SIP phone.
I’m looking to get a DDI number.
Can i use this phone easily ?
How’s incoming calls rates ?
Outcoming calls rates ,?
Hi @anibal_ventura
Thank you for considering us.
Setting up a FlyNumber with a Yealink phone should be easy with our phone system.
You can check out this post which gets into setting up the SIP credentials
Answer with the SIP phone and its unlimited free incoming.
If you get a DID number (i.e. FlyNumber) from the same country you call often the per min rate is usually much cheaper.
A blog post on that…
