Currently, I have PBX configured to forward incoming calls to the Freecall VOIP provider. My SIP device then is configured to connect to Freecall which works fine. Outgoing calls are then sent via Freecall.
However, that means I don’t have much control over outgoing calls and I would like to use PBX for them. So if I connect my SIP device directly to Flynumber and then my incoming calls are received without forwarding but I would want to direct all outgoing calls to Freecall (using features to select the CallerID based on which country I am calling etc).
Perhaps it is just me but I cannot see how to configure PBX to do something like this with outgoing calls. Can you point me in the right direction?
