Yes we can definitely help, many of our customers use the same way you described. The Canada number can be reached by any phone number in the world, so as long as your smartphone has data you’ll be fine.
We won’t need this unless you send the FlyNumber calls to a “regular phone number”. Instead, it would be more efficient to send calls to an app and take advantage of the 3G/4G/5G on your smartphone. This way it’s unlimited incoming, where as if you forward calls to the Russian phone number there will be a per min rate.
No need but you’ll want a good data plan, not necessarily a high amount of gigabytes, but a good quality network is ideal.
If you’re Russian Sim can provide that then great, otherwise you may want to look into getting a prepaid sim card, possibly data only (in Turkey)
The service will work great with the iOS
You absolutely can, sign up here - choose a Canada number and set to any forwarding option
(Select PBX as this can be changed later)
Please let us know if you have any other questions or concerns
