I am evaluating FlyNumber for a commercial AI receptionist platform that will use Nigerian (+234) numbers and connect incoming calls to our SIP/Vapi infrastructure.
Before we proceed with a potentially large number of subscriptions, I would like to clarify your current capabilities and pricing for higher-volume use.
Could you please answer the following:
1. Nigerian numbers
What is the current monthly price for Nigerian local numbers?
Are there any setup, activation, regulatory, or KYC fees?
Can we provision approximately 50 Nigerian numbers under one account?
Do you offer discounts for bulk subscriptions?
2. Inbound SIP/VoIP
Can every Nigerian number be connected directly to an external SIP endpoint?
Are incoming calls delivered to our SIP server/Vapi without requiring call forwarding through a traditional PSTN destination?
Is inbound SIP/VoIP calling included in the monthly number subscription, or are inbound minutes charged separately?
If included, is there a fair-use or monthly-minute limit?
Are there any additional charges for SIP usage?
3. Concurrent calls / channels
How many simultaneous inbound calls are currently supported per Nigerian number?
I have seen older information indicating a limit of 2 concurrent calls per number. Is that still the current limit?
Can additional channels be purchased for a single number?
If so, what is the current price per additional channel?
Is there an account-wide concurrent-call limit?
Could you support approximately 50, 100, or 500 simultaneous inbound calls across an account with multiple Nigerian numbers?
4. Scaling
If we eventually have 50–100 Nigerian numbers, can all of them route simultaneously to the same SIP/Vapi infrastructure?
Are there any calls-per-second (CPS) limits?
Are there any account-level traffic limits that we should know about?
Do you offer higher concurrency or enterprise capacity on request?
5. Outbound calling
Can the Nigerian numbers also be used for outbound VoIP/SIP calls?
What is the current outbound rate for calls from Nigerian numbers?
Are outbound calls charged per minute?
Are there any concurrency or CPS limits for outbound calls?
6. SIP/Vapi compatibility
Do you provide standard SIP credentials that can be used with Vapi or another SIP platform?
Do you support SIP over TLS and/or SRTP?
Are there any restrictions on connecting the numbers to an external AI voice platform such as Vapi?
Can we use our own SIP infrastructure while FlyNumber provides the Nigerian DIDs?
7. Commercial/enterprise arrangements
Do you offer custom pricing for approximately 50 Nigerian numbers and high call volumes?
If so, could you provide an example quotation for 50 numbers with approximately 100 concurrent inbound calls?
Could you also provide pricing for approximately 500 concurrent calls, if available?
Our primary requirement is high-volume inbound AI receptionist traffic, so the most important factors for us are the cost of Nigerian numbers, whether inbound SIP minutes are included, and the maximum simultaneous-call capacity.
We would appreciate current 2026 pricing and limits rather than historical figures from older documentation.
Thanks for the details — answers inline, current as of September 2026.
Nigerian numbers
$19.95/month per Nigerian local number (Lagos +234 1, Abuja +234 9). No setup, activation or regulatory fees.
Registration is required but light: name, contact phone number, company name, and a business address (any country). No document uploads, no fee.
Stock is the one constraint. Nigeria isn’t an instant-provisioning country for us — we currently have 9 numbers immediately available. 50 is doable, but it’s a stock request to the carrier, not a same-day self-serve purchase. Tell me the split you want between Lagos and Abuja and I’ll confirm quantity and lead time.
Yes to bulk pricing at 50+ — see the quote below.
Inbound SIP / VoIP
Every number can point directly at your own SIP endpoint (host or SIP URI). No PSTN leg, no forwarding to a phone number.
Inbound delivery to SIP is included in the monthly price — no per-minute inbound charge, no monthly minute bundle, no fair-use cap. Your capacity limit is concurrent channels, not minutes.
No extra SIP usage fees.
We have a documented Vapi path: create a BYO SIP trunk in Vapi, add our gateway 138.197.42.26 with inbound calls + OPTIONS ping enabled, then point the number at {credential_id}.sip.vapi.ai. Full guide: https://docs.flynumber.com/basic-settings/set-voip (LiveKit, ElevenLabs and Retell are covered there too).
Concurrency
2 concurrent calls per number is still current, and it’s included in the $19.95.
Additional channels can be added to a number — Nigeria supports it. That’s quoted per order rather than listed publicly; tell me the target and I’ll price it.
There’s no fixed account-wide concurrency cap. 50 and 100 concurrent are routine; 500 is fine as a planned build, we just size the capacity with you first.
Scaling
Yes — 50-100 numbers can all route to the same SIP/Vapi infrastructure simultaneously.
No published CPS limit at your volume. For a burst profile well above normal, we’d agree on a ceiling in advance rather than let it hit a surprise limit.
No other account-level traffic limits to worry about, and yes, we do higher-concurrency/enterprise capacity on request.
Outbound
Yes, the Nigerian numbers support outbound.
Outbound is per-minute from your prepaid balance, billed by the second on most routes. Live rates: FlyNumber per-minute rates and SMS pricing | FlyNumber — the price depends on destination, not on the number’s country.
Outbound concurrency follows the same channel capacity as inbound.
SIP compatibility
Standard SIP credentials, usable with Vapi or any SIP platform. TLS and SRTP supported (5061); UDP on 5060 if you prefer.
No restrictions on connecting to an external AI voice platform.
Using your own SIP infrastructure with us supplying the Nigerian DIDs is exactly the intended setup.
Example quotation
50 Nigerian numbers
$997.50/month
Concurrent inbound included
100 (2 per number)
Setup / activation
$0
Inbound SIP minutes
Included
So your 100-concurrent target is met by the base configuration. For 500 concurrent we’d add 400 channels of capacity on top — send me the target and I’ll come back with a firm number, along with volume pricing on the 50 subscriptions.
Best way forward: confirm the Lagos/Abuja split and your concurrency target, and I’ll check live stock and send a firm quote.
