Send an email when a call is recieved
I’ve been using the PBXww to try and fire off an email when a call is received but it seems to not allow this. Is there a way I can get an email when a number is called?
What error are you getting?
That is what the "notification " module is supposed to do. Make sure you’re putting it in between the phone number and person module
Check your spam/junk folder for the emails and perhaps try a different email address just in case
Let us know if this persists
Thanks for the reply. I was trying to connect both points at once and it wouldn’t . I’ve set from the number to the notification now and then to the person.
Thanks for the help!
Glad to hear its working and thanks for the feedback!
