I see you’re able to record incoming phone calls made to the Flynumber…
Is there the possibility to record outgoing calls when using Flynumbers SIP credentials?
Yes you can, this is actually a new feature and can be enabled using our PBX/ Virtual Phone System
Let us know if you have any other questions
