Disconnect call after audio playback block
I would like to configure my Phone systems (fka. PBXww) to disconnect the call automatically after an audio playback has finished. How can I do that?
If I leave the audio playback block output unconnected to another block, there will be an error voice message that says “The number you have reached requires configuration, please configure …” at the end of the call before the call drops. Is there anyway Flynumber can remove the error voice message? Or can there be a “End call block” to end the call?
At the moment the playback module can’t be used to end a call
You can end a call route by using a voice menu object with timeout set along with the call function enabled and a non-working object assigned.
Not perfect but should work fine in your situation
