manaf
1
I want to order a flyNumber. I have to choose PBX as option. Then you talked about Groundwire (Acrobits).
I haven’t find it in the app store (France).
- If it doesn’t exist (in France), Is Bria right for me or do you suggest another app?
- Do you have a guide for the configuration?
Thanks.
Any SIP client would work, can you try switching your country in the App store ( although you might need a USA credit card in this case)
Try searching “groundwire” or “acorbits” exclusively
You can follow step 2 of this post to see how to obtain SIP info
http://www.flynumber.com/blog/how-to-use-your-flynumber-sip-account-to-make-and-receive-calls-on-a-pc/
