Call Forwarding - does it announce it's a flynumber call
Can you set it up so that when you receive a forwarded call there is a warning that the call is coming from a flynumber call? I want to make sure I am forewarned so that I answer properly. I was able to do this on my phone.com virtual office.
Thanks.
Hello FlyNumber,
Is the whisper option available yet?
Thank you!
We have something similar to a whisper feature but only when using landline/mobile forwarding
Its called “Call Confirmation” and you are asked about this when you set a forwarding number in the PBX panel ( in the Person module)
Every time someone calls your FlyNumber it will ask you if you want to accept or deny the call, using this method will let you know if the call is a FlyNumber call
Thank you so much for the fast reply!
